Hello, Everyone, in this video guide, I going to show you how to disassemble PS5 and clean the fan and heatsink from dust. Over time, the radiator inside of the PlayStation 5 becomes clogged with dust, and the system overheats. To solve this problem, you need to clean your game console.
crwdns2936621:0crwdne2936621:0
Gracefully shutdown the PS5
Unplug all cables and move to a clean working area.
Gather required tools
TR8 Torx(security bit)
P1 Screw Driver
Magnetic Project Mat
Plastic prying tools and Spudger.
Remove Optical side cover
If the optical drive is closest to you, lift up on top left corner.
Clean accessible areas with a non-static brush, compressed-air, or vacuum.
When finished, flip over to remove PS logo side panel.
Remove cover by gently pulling up on corner by PS logo a sliding towards the Vertical Botton of PS5.
Clean area as much as possible
Now flip the ps5 back over to the optical bay side.
Using a spludger tool:
Carefully pry inlet grill from top-left to bottom right.
Remove Molex connection cover using flat end of plastic probe
Using two spludgers
Pry either side of the fan molex connector to disconnect.
TR8 Bit: Remove 4 x screws
2x Screw w/ machine threads top-right and bottom-right (23.3mm)
1x Short screw with coarse threads on bottom left (11.4mm)
1x Long screw w/ coarse threads on top-left (31mm)
Remove fan cover
Remove fan assembly
If heavy accumulation of dust is present on heatsink, proceed with further disassembly.
Use P1 bit driver to remove 1 x Screw
Remove m.2 cover plate and set aside.
Disconnect 2x Molex connectors
Proceeding further will void your manufacturer warranty. Proceed at your own risk!
Remove stick to reveal TR8 bit head screw
TR8 Bit: Remove 11 x screws
These screws vary in sizes so pay attention to where they go.
Remove cover.
Use spudger to depress metal clip for ribbon cable connecting from the main unit to the optical drive.
The optical drive can now be removed and set aside.
Remove 3x Ribbon Cables
Remove 2 x uFL Wifi
RW & RB
FW & FB
Remove 41 X Torx Screws (Silver Screws)
Remove 1 X Torx Black Screw
Disconnect Ribbon Cable
Flip over
Remove 2 x Torx Screws (29.4mm)
Remove Cover
Remove Power Supply by pulling up
Follow these steps in reverse or follow above video.
crwdns2935229:027crwdne2935229:0
crwdns2947412:015crwdne2947412:0
Thanks for the great guide which I have been using with success. I wonder if you know specifically what compound (not pads) there is on the capacitors and ram under the shield. Thank you
Thanks! Man that was alot of screws!
Awesome video, and one that showed you how to put it back together!! much appreciated sir
This was my second time tearing down the PS5 to clean it... and it was still a very annoying process.
It was made much easier with this guide, though. Thanks for all the work you put in to making it! Much appreciated.
Now it's my 3rd time using this guild to tear down the PS5. Greatly appreciate the time & effort that went to in making this guide... It's the gift that keeps on giving!
Thanks for tutorial. You just saved me some money
Good morning. I did everything correctly, but the PS5 still shows being overheated. What should I do ?. Please
FYI in some versions of the PS5, you do not need to remove the large metal plate from the motherboard. They uncovered one of the ribbon cables so you can disconnect it with out all the hassle of tons of screws.
After I finidhed the guide, My ps5 shutdown again due to "overheating". But the guide was nonetheless amazing. I just dont know what else I can do
Did you try blowing out the transformer with some compressed air? Mine had a lot of gunk, and was the reason for the random shutdowns.
My PS5 keeps switched off suddenly after about a hour of it being on, I have hooveredy using the hoover vents but, I feel like something is blocking the vents. I'm not technically mindedly but this guide makes it pretty easy, I feel like this is worth a shot to see if it's that problem, are there any warranty stickers in the process?
In this Video it explains perfectly what you can do and what not, I hope this answers your question, let me know.
anyone know where the temperature sensors on the motherboard are?
Many thanks. This is an excellent video.
Thanks bruh!
