How to fix PS5 overheating
crwdns2936621:0crwdne2936621:0
    • Backup PS5 if possible
    • Gracefully shutdown the PS5
    • Unplug all cables and move to a clean working area.
    • Gather required tools
    • TR8 Torx(security bit)
    • P1 Screw Driver
    • Magnetic Project Mat
    • Plastic prying tools and Spudger.
    • Remove Optical side cover
    • If the optical drive is closest to you, lift up on top left corner.
    • Clean accessible areas with a non-static brush, compressed-air, or vacuum.
    • When finished, flip over to remove PS logo side panel.
    • Remove cover by gently pulling up on corner by PS logo a sliding towards the Vertical Botton of PS5.
    • Clean area as much as possible
    • Now flip the ps5 back over to the optical bay side.
    • Using a spludger tool:
    • Carefully pry inlet grill from top-left to bottom right.
    • Remove Molex connection cover using flat end of plastic probe
    • Using two spludgers
    • Pry either side of the fan molex connector to disconnect.
    • TR8 Bit: Remove 4 x screws
    • 2x Screw w/ machine threads top-right and bottom-right (23.3mm)
    • 1x Short screw with coarse threads on bottom left (11.4mm)
    • 1x Long screw w/ coarse threads on top-left (31mm)
    • Remove fan cover
    • Remove fan assembly
    • If heavy accumulation of dust is present on heatsink, proceed with further disassembly.
    • Use P1 bit driver to remove 1 x Screw
    • Remove m.2 cover plate and set aside.
    • Disconnect 2x Molex connectors
    • Proceeding further will void your manufacturer warranty. Proceed at your own risk!
    • Remove stick to reveal TR8 bit head screw
    • TR8 Bit: Remove 11 x screws
    • These screws vary in sizes so pay attention to where they go.
    • Remove cover.
    • Use spudger to depress metal clip for ribbon cable connecting from the main unit to the optical drive.
    • The optical drive can now be removed and set aside.
    • Remove 3x Ribbon Cables
    • Remove 2 x uFL Wifi
    • RW & RB
    • FW & FB
    • Remove 41 X Torx Screws (Silver Screws)
    • Remove 1 X Torx Black Screw
    • Disconnect Ribbon Cable
    • Flip over
    • Remove 2 x Torx Screws (29.4mm)
    • Remove Cover
    • Remove Power Supply by pulling up
    • Follow these steps in reverse or follow above video.
crwdns2935229:027crwdne2935229:0
Arty
crwdns2935283:010/27/19crwdne2935283:0
31,054 crwdns2915208:0crwdne2915208:0
crwdns2935297:0108crwdne2935297:0
crwdns2947412:016crwdne2947412:0
Thanks for the great guide which I have been using with success. I wonder if you know specifically what compound (not pads) there is on the capacitors and ram under the shield. Thank you
Ander x - crwdns2934203:0crwdne2934203:0
Thanks! Man that was alot of screws!
RadioShack - crwdns2934203:0crwdne2934203:0
Awesome video, and one that showed you how to put it back together!! much appreciated sir
Alex Blackwood - crwdns2934203:0crwdne2934203:0
This was my second time tearing down the PS5 to clean it... and it was still a very annoying process.
It was made much easier with this guide, though. Thanks for all the work you put in to making it! Much appreciated.
Matthew D. H. - crwdns2934203:0crwdne2934203:0
Now it's my 3rd time using this guild to tear down the PS5. Greatly appreciate the time & effort that went to in making this guide... It's the gift that keeps on giving!
Matthew D. H. -
crwdns2936751:024crwdne2936751:0 56
crwdns2936753:07crwdne2936753:0 422
crwdns2936753:030crwdne2936753:0 2,075
crwdns2942667:0crwdne2942667:0 157,029
