How to fix PS5 overheating
crwdns2869540:0crwdne2869540:0: 193 тыс.
147
989
4 444
192 515
crwdns2955950:0crwdne2955950:0: 16
crwdns2960008:016crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 30
crwdns2959974:030crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 10
crwdns2959982:010crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:040crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
Hello, Everyone, in this video guide, I going to show you how to disassemble PS5 and clean the fan and heatsink from dust. Over time, the radiator inside of the PlayStation 5 becomes clogged with dust, and the system overheats. To solve this problem, you need to clean your game console.
crwdns2936621:0crwdne2936621:0
      • Backup PS5 if possible
      • Gracefully shutdown the PS5
      • Unplug all cables and move to a clean working area.
      • Gather required tools
      • TR8 Torx(security bit)
      • P1 Screw Driver
      • Magnetic Project Mat
      • Plastic prying tools and Spudger.
      • Remove Optical side cover
      • If the optical drive is closest to you, lift up on top left corner.
      • Clean accessible areas with a non-static brush, compressed-air, or vacuum.
      • When finished, flip over to remove PS logo side panel.
      • Remove cover by gently pulling up on corner by PS logo a sliding towards the Vertical Botton of PS5.
      • Clean area as much as possible
      • Now flip the ps5 back over to the optical bay side.
      • Using a spludger tool:
      • Carefully pry inlet grill from top-left to bottom right.
      • Remove Molex connection cover using flat end of plastic probe
      • Using two spludgers
      • Pry either side of the fan molex connector to disconnect.
      • TR8 Bit: Remove 4 x screws
      • 2x Screw w/ machine threads top-right and bottom-right (23.3mm)
      • 1x Short screw with coarse threads on bottom left (11.4mm)
      • 1x Long screw w/ coarse threads on top-left (31mm)
      • Remove fan cover
      • Remove fan assembly
      • If heavy accumulation of dust is present on heatsink, proceed with further disassembly.
      • Use P1 bit driver to remove 1 x Screw
      • Remove m.2 cover plate and set aside.
      • Disconnect 2x Molex connectors
      • Proceeding further will void your manufacturer warranty. Proceed at your own risk!
      • Remove stick to reveal TR8 bit head screw
      • TR8 Bit: Remove 11 x screws
      • These screws vary in sizes so pay attention to where they go.
      • Remove cover.
      • Use spudger to depress metal clip for ribbon cable connecting from the main unit to the optical drive.
      • The optical drive can now be removed and set aside.
      • Remove 3x Ribbon Cables
      • Remove 2 x uFL Wifi
      • RW & RB
      • FW & FB
      • Remove 41 X Torx Screws (Silver Screws)
      • Remove 1 X Torx Black Screw
      • Disconnect Ribbon Cable
      • Flip over
      • Remove 2 x Torx Screws (29.4mm)
      • Remove Cover
      • Remove Power Supply by pulling up
      • Follow these steps in reverse or follow above video.
crwdns2935229:030crwdne2935229:0
Arty
crwdns2935283:010/27/19crwdne2935283:0
34 694 crwdns2915208:0crwdne2915208:0
crwdns2935297:0110crwdne2935297:0
crwdns2947412:016crwdne2947412:0
Thanks for the great guide which I have been using with success. I wonder if you know specifically what compound (not pads) there is on the capacitors and ram under the shield. Thank you
Ander x - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks! Man that was alot of screws!
RadioShack SLO - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Awesome video, and one that showed you how to put it back together!! much appreciated sir
Alex Blackwood - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This was my second time tearing down the PS5 to clean it... and it was still a very annoying process.
It was made much easier with this guide, though. Thanks for all the work you put in to making it! Much appreciated.
Matthew D. H. - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Now it's my 3rd time using this guild to tear down the PS5. Greatly appreciate the time & effort that went to in making this guide... It's the gift that keeps on giving!
crwdns2936751:024crwdne2936751:0 147
crwdns2936753:07crwdne2936753:0 989
crwdns2936753:030crwdne2936753:0 4,444
crwdns2959996:0crwdne2959996:0 192,515
