How to fix Mobee Magic Mouse disconnection issues
crwdns2869540:0crwdne2869540:0: 42K
6
31
194
42,297
crwdns2955950:0crwdne2955950:0: 5
crwdns2960008:05crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 31
crwdns2959974:031crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 3
crwdns2959982:03crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
crwdns2955970:0crwdne2955970:0: crwdns2937585:0crwdne2937585:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
I came here looking for a solution to my intermittent connection problems on my Mobee Magic Mouse - Apple iMac. I could not find anything, but I found this YouTube guide which has solved the problem.
crwdns2937549:0crwdne2937549:0
crwdns2935229:031crwdne2935229:0
Peter Barnett
crwdns2935283:009/04/16crwdne2935283:0
771 crwdns2915208:0crwdne2915208:0
Dragon Upstream Consulting Limited crwdns2935289:0Dragon Upstream Consulting Limitedcrwdne2935289:0
Business
crwdns2947412:05crwdne2947412:0
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What is the screw type and size for the Magic Mouse battery pack? They're so small I can barely see them! Are they tiny Allen/Hex heads?
Jeffrey Powell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 194
crwdns2959996:0crwdne2959996:0 42,297
