How to fix Logitech M171 Mouse Laser
crwdns2942287:0crwdne2942287:0In this guide we will be showing you how to fix your Logitech M171 mouse laser not working
Remove the plastic cover at the bottom of the mouse
Remove the battery and wireless key
Remove the front cover as show
Do not do this! There are three clips under the mouse, you just need to move them gently out of the way. Two are available when the battery cover is removed, the third is accessible after you remove the battery.
Pull on the sensor to remove it
Clean the sensor with an tissue soaked in alcohol
Insert sensor as shown
Install the front plate put the front plate down on the mouse and push Down until it clips in
Install battery and USB key and back cover and you’re done
You’re done Thanks for completing the guide
Frying the darker plastic cover open without damaging it is near impossible. I have a problem with my mouse wheel and I don't know how to lubricate it or fix the sensor. Can someone help with that?
These are bad instructions, the top is released with 3 clips accessible under the battery cover, prising it off from above will break those clips. It can be hard to work out where the clips are and how to release them, but there are 3 one on each side and on under the battery. Aside from that the only other retention is a couple of hooks on the mouse buttons.
Agree that prizing the top off like this is going to damage it! Maybe my mouse, being blue on top, and black on bottom made this easier to spot, but it was very easy for me to see the three clips on the bottom. Hopefully anyone who wants to open theirs will see your comment and not use the opening tool like this.
Sid R -
