Due to the many problems with cell phone signal and gps on LG G2, i will show you how to boost your gps and cell phone signal in 2 min.
Just watch the video below:
crwdns2936621:0crwdne2936621:0
Open the back panel and locate these three connectors.
Cut the pieces close to the size of the connectors.
Place the cardboard pieces under all three connectors.
Close the back panel.
I believe it did not work on my set, rather some of the clips on the back cover broke while taking it off
crwdns2935229:020crwdne2935229:0
crwdns2944067:07crwdne2944067:0
THANK YOU THANK YOU! Gps locks in seconds and stays locked instead of locking then unlocking after 2 minutes like before. Big ups!
Vielen Dank, GPS funktioniert bei mir wieder richtig gut. Einer der 3 Kontakte war gut verklebt. Er musste mit einem Teppichmesser unterschnitten werden, was äusserste Vorsicht erfordert.
GPS bug I encountered: being from time to time located 50m northward (upsetting when the mains highways are E-W). Working great for the moment :-)
This solution saved me! Thanks a lot.
Sir... Thank you! I was considering to buy another phone, but i love my LGG3 D855 this worked for me too.
I would hug you if i could, thank you! (Hail from Brazil!)
thank you very much!!! last week I had terrible problem with the gps signal!! with your fix my phone is working like new
My GPS had been sporadic ever since Pokemon Go launched (never used it much before then). Some days weren't bad, other days I couldn't get a stable enough signal to do much of anything.
After venting my frustrations a bit on the phone, the back cover came slightly loose in one corner, and I recalled this DIY fix, tried it out, and thus far the GPS has been more stable/accurate than it EVER was.
Hopefully this fix lasts. I was beginning to compare features on new (0-dollar) phones. it was starting to give me a headache figuring out what features I could live without, and what was/wasn't an upgrade... (Probably going to need to upgrade soon anyway, as the OS isn't being updated for this model)
This will NOT do anything for cell/gps signal the connectors on the back panel are for NFC, nothing more.
kansasboy001 - crwdns2934203:0crwdne2934203:0
NFC connector is just the one next to the camera&key opening.
Blaz - crwdns2934203:0crwdne2934203:0
