How to determine the cause for a restart in Kali Linux
    • Press Ctrl + Alt + T to open the Terminal Interface.
    • Enter the command sudo mkdir /var/log/journal
    • Enter the command: sudo systemd-tmpfiles --create --prefix /var/log/journal 2>/dev/null
    • sudo systemctl -s SIGUSR1 kill systemd-journald
    • Once this command is run, you will need to restart your machine to get your current system logs.
    • See your logged boots from your journal with the following: journalctl --list-boots
    • Locate a specific reboot using this command: journalctl -b {num} -n
Optionally you can use killall -USR1 systemd-journald rather than restarting your services. This way a user can keep all the logging from the current session.
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
40,137 crwdns2915208:0crwdne2915208:0
crwdns2935297:050crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:061crwdne2931471:0
crwdns2935297:0203crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,029
