How to crack a Euro Cylinder
  1. How to crack a Euro Cylinder, Explanation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to crack a Euro Cylinder, Explanation: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to crack a Euro Cylinder, Explanation: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Most euro cylinders have a weak spot where the tread for the fixing screw is. You can easily break the lock by fatiguing the metal until it snaps.
    • There are ways to protect against this, with p. ex. hardened insterts that hold the lock together.
    • These protections, in contrast to drill protection, are typically only found in high-end security locks, however.
    • Professionals use a tool called a Cylinder Cracker for this purpose. The adjustable clamp adaptor, which features a profile on the inside, grips the cylinder and easily breaks it, even if there's very little overhead (only approximately 2 mm required for high-quality tools) to grab onto.
  2. How to crack a Euro Cylinder, Remove the Handle and Faceplate: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to crack a Euro Cylinder, Remove the Handle and Faceplate: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In this case you wouldn't actually have to remove the faceplate because the core sticks out enough to grab on to it, but removing the faceplate makes it easier to grab the core.
    • If you have a security faceplate that you can't remove and the core doesn't stick out enough to grab on to, you can't break the lock with this method. You might need to try other methods like drilling the pins out instead.
    • Remove the handle and faceplate.
    • To remove the faceplate, you'll have to remove the handles first. The handle is typically held by a small grub screw somewhere near the base of the handle.
    • If you can remove the faceplate from your side, you can typically see all the screws that you have to unscrew to remove the faceplate.
  3. How to crack a Euro Cylinder, Break the Cylinder: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to crack a Euro Cylinder, Break the Cylinder: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the cylinder with a pipe wrench.
    • You may do it vertically, as shown in the picture, or horizontally.
    • Wiggle the cylinder up, down, left and right until you feel the core come loose with a snap.
    • You don't need any large movements, so you can keep them to a minimum to not damage the faceplate, if you still have it attached.
  4. How to crack a Euro Cylinder, Remove the Core: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the detached core half.
  5. How to crack a Euro Cylinder, Unlock the Door (if locked): crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to crack a Euro Cylinder, Unlock the Door (if locked): crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a construction key to unlock the door, if it is locked.
Having removed the core you can now replace it with a new one.
Sebastian
crwdns2935283:008/19/18crwdne2935283:0
30,234 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 130
crwdns2942667:0crwdne2942667:0 3,302
