Go to https://www.samsung.com/levant/support/k... , download and install the program.
Follow the installation wizard and configure the app as you like.
You may have to update the program.
From the main menu, go to Settings,
Then select the 8th option "PC connections",
Finally, select the option "Samsung Kies".
While the phone is connecting, you will see this screen.
Lastly, you have finally connected your phone successfully to your PC! Explore your options via Samsung Kies!
Close to program and disconnect your device.
