How to configure "Client Mode" on TP-Link TL-WR802N
  1. How to configure "Client Mode" on TP-Link TL-WR802N, How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reset router to a factory (reset button for 5-10 seconds).
  2. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use PC to connect through WiFi to TP-LINK_xx SSID.
  3. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the browser open a page with IP address 192.169.0.1 (usually default gateway), and login using admin/admin
  4. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Go through setup steps: [Next] -> select “Client” mode -> [Next]
    • Select AP with SSID you want to use it with (if does not appear, refresh it). Then hit [Next]
    • Confirm SSID, specify security settings, shared key if needed, etc. -> [Next]
  5. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Select type: “Static IP”
    • Configure static IP address within your wireless network (preferably outside your DHCP scope)
    • Configure subnet mask as needed
    • Make sure “DHCP Server” is “Enabled”
    • [Next] -> Reboot
  6. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After this you need to connect another PC to the Ethernet port. It should get IP address from your wireless network, but it will be unable to communicate to the rest of the network, only to the router.
    • *** Generally that’s where “User Manual” stops...
  7. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Go to the browser and connect to IP address of the router (which you just configured above). Login with admin/admin
  8. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Go to “Network” section, and configure “Gateway” as the “default gateway” of your WiFi network (after wizard it comes as a TP-Link router address)
    • Hit “Save” and router will reboot.
    • After reboot you will be able to access router from either LAN or locally connected PC (local connection may be faster and more reliable).
  9. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Login again (if needed), and now go to DHCP section
    • DHCP Server: Enabled
    • Start IP: <start IP address> End IP: <end IP address>
    • Gateway: <IP address of WiFi network gateway>
    • Domain: <your domain>
    • DNS: <your DNS servers>
  10. How to configure "Client Mode" on TP-Link TL-WR802N: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After this – disconnect Ethernet, power off router, then reboot PC (it may retain default route of the TP-Link router, better reboot it), and then connect Ethernet.
    • You will be connected to the WiFi network, repeat it a couple times to make sure the process is repeatable.
Headset Adapter Co
crwdns2935283:003/15/17crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 11,968
