How to clean the Shure SM58
nat coll
crwdns2944107:0crwdnd2944107:0nat collcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 20, 2025crwdne2944111:0
20 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
All of the internal surfaces, especially the conductive metal pieces, need to be clean and well kept in order for the microphone to function at its best.
crwdns2944105:0crwdne2944105:0
  1. How to clean the Shure SM58, Collar: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to clean the Shure SM58, Collar: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to clean the Shure SM58, Collar: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. How to clean the Shure SM58, How to clean the Shure SM58: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
    • Using a detailing brush and the solution, gently brush the pins and inside walls of the microphone.
  3. How to clean the Shure SM58: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure connector is completely dry before soldering, failure to do so may result in permanent damage.
    • If you have previously soldered inside the microphone, you may use a soldering iron to melt off any excess solder that may be on the pins inside the connector. Do not attempt this if you have never soldered on the microphone before.
After cleaning the faceplate and reassembling the microphone, it should work at its maximum potential.
nat coll
crwdns2935283:009/27/12crwdne2935283:0
736 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-53, Forte Fall 2012 crwdns2935289:0Cal Poly, Team 7-53, Forte Fall 2012crwdne2935289:0
CPSU-FORTE-F12S7G53
crwdns2935297:030crwdne2935297:0
Thanks for the join. I’m checking out the Shure Sm-58 repair. Thanks for the info
Mike gallagher - crwdns2934203:0crwdne2934203:0
Hi I checked the solder on the wires inside the microphone and it still does not work. Any other ideas?
karl_ivers - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 11,210
