Using a Phillips size 0 screwdriver, remove the 2 screws from the bottom of the camera
Remove the screw located on the right side of the camera
Remove the two screws from the left side of the camera
Use a small prying device to delicately separate the front casing from the back. New line.
Remove the 2 screws on the right side of the camera.
Remove the 2 screwson the left side of the camera
Carefully flip up the clip attaching the ribbon from the rear to the front and pull it out
Carefully separate the front and back of the camera
Using a size 0 Phillips head, remove 3 screws holding the ribbon cable that covers the back of the lens.
Using tweezers remove tiny square lens cases. There are 4 small pieces.
Remove the larger black rubber frame. Clean with condensed air.
