How to clean the HP Pavilion 550
  1. How to clean the HP Pavilion 550, How to clean the HP Pavilion 550: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550, How to clean the HP Pavilion 550: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the computer from the power outlet by unplugging the power cord.
    • Unplug all peripherals from the computer.
    • Stand the desktop tower upright so that the back of the tower is facing you.
    • Remove thumbscrew below the side panel handle.
  2. How to clean the HP Pavilion 550: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the retaining thumbscrew is removed, pull off the side panel to expose the internal components.
    • Lay the computer down so that the opened side is facing you.
  3. How to clean the HP Pavilion 550: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clip an anti-static bracelet to any exposed metal on the computer chassis.
    • Make sure the metal does not have paint on it as this will reduce the effectiveness of the bracelet.
    • Always wear the bracelet when handling the circuit boards.
  4. How to clean the HP Pavilion 550: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the hard drive located near the front panel of the case.
    • Remove the for screws holding the hard drive in place.
    • Make sure to reattach the wire connected to this screw when putting the hard drive back in.
    • With your hand under the drive, slide the drive out from the caddy in the direction indicated by the arrow.
  5. How to clean the HP Pavilion 550: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the flat and wide SATA cables.
    • The SATA cables can simply be removed by holding the head of the cable and carefully pulling them out.
  6. How to clean the HP Pavilion 550: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all the connections located at the bottom of the circuit board.
    • Some connectors may have a locking clip that has to be pressed in order to remove the cable.
  7. How to clean the HP Pavilion 550: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the chassis fan header cable.
    • This cable usually has a red, black, and yellow wire.
    • Press the clip on the connector and disconnect the cable from the circuit board.
  8. How to clean the HP Pavilion 550: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws holding the chassis fan in place.
    • Set aside the fan for clean up.
  9. How to clean the HP Pavilion 550: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all screws holding the circuit board in place.
    • Keep the screws in organized clusters as this will ease your reassembly of the computer.
    • Do not forcibly remove the board. Check if there are any screws still in place.
  10. How to clean the HP Pavilion 550: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the Wi-Fi card and remove the antenna cables connected to the card.
  11. How to clean the HP Pavilion 550: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the circuit board is loose, gently lift the board out of the case and place the board onto a non-conductive surface.
  12. How to clean the HP Pavilion 550: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the RAM module and press the white tabs to remove the RAM.
    • Set the RAM on a static-free surface.
    • Remove the screws attaching the CPU fan to the CPU heatsink.
    • Set aside the fan for cleaning.
  13. How to clean the HP Pavilion 550: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the heatsink retaining clips to remove the heatsink.
  14. How to clean the HP Pavilion 550: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Prepare the Q-tips and isopropyl alcohol.
    • Remove as much of the thermal paste on the CPU as possible.
    • A microfiber cloth can be used to remove any remaining thermal paste present on the CPU.
    • Do not allow thermal paste to touch the small electrical components on the CPU.
  15. How to clean the HP Pavilion 550: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put a small pea-sized drop of fresh thermal paste onto the CPU.
    • The CPU heatsink can now be secured back in place.
    • There is no need to spread the paste out. The heatsink pressure will automatically spread out the thermal compound evenly.
  16. How to clean the HP Pavilion 550: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a vacuum and/or compressed air to remove dust from the chassis fan.
  17. How to clean the HP Pavilion 550: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use compressed air or a vacuum to remove dust from the CPU fan.
  18. How to clean the HP Pavilion 550: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If dust is present on the hard drive, remove it using compressed air.
    • Avoid touching the circuit board as this could cause electrical damage to the board.
  19. How to clean the HP Pavilion 550: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect the computer case and remove any dust using a vacuum, towel, or compressed air.
  20. How to clean the HP Pavilion 550: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the circuit board back into the case and secure the board using the screws removed earlier.
    • After the circuit board is secured, secure the fan using its specific screws.
    • Insert the hard drive and reattach it using the correct screws.
  21. How to clean the HP Pavilion 550: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean the HP Pavilion 550: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reattach the antenna cables to the Wi-Fi card.
    • Reattach all the SATA cables and peripheral cables.
  22. How to clean the HP Pavilion 550: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once every component is secured inside the case, slide the side panel back on and secure it using the thumbscrew.
Peter Le
crwdns2935283:011/22/21crwdne2935283:0
325 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 400
