Before accessing the joystick, several prerequisite steps are required. This guide will show you how to disassemble to device in order to access the joystick for proper maintenance.
Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
Remove the rubber plug located near the camera by gently prying upward with your fingers.
Gently lift the camera shield after removal of the rubber plug.
Pry the remaining panel to loosen its contact to the phone using a spudger.
Slide the panel upward to remove it completely.
Slide the aerial upward to remove it.
Remove the four screws located at each corner of the device.
Gently lift and remove the front panel of the phone after removing the screws.
Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
Gently pull the ribbon from the circuit.
Remove the now disconnected screen.
Remove the keyboard by slowly pulling it away from the circuit board.
Gently lift the white circuit board to reveal the base.
Soak cotton swab in rubbing alcohol
Gently work the cotton swab around the joystick, removing any waste buildup that may hinder its use.
