Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
Unclip the three latches on the bottom of the device.
Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
Use the screwdriver to remove two screws on either side of the silver security bar.
Pull out the silver security bar and set aside.
Take out the two screws on either side of the green circuit board.
Carefully lift the board just enough to remove the disk drive.
Remove the two screws at the back of the disk drive.
Gently lift the disk drive out of the DVD player.
Turn disc drive over so you can see the gears on the bottom.
Using a cotton swap or a cleansing cloth and alcohol, gently rub the gears ridding of any debris and dust.
You can also use a compressed air can as well. Just point the nozzle at the gears and spray with the compressed air.
