How to clean Apple EarPods
  1. How to clean Apple EarPods, Apple EarPods cleaning: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If your EarPods are dirty with dust or wax, or anything else on the ear pieces, follow these steps to clean them.
  2. How to clean Apple EarPods: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean Apple EarPods: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a toothpick to rub all the holes in the earphone
    • Don't use a pencil, it lets waste or any other metal tool, you can puncture the earpod and ruin it.
    using toothpick can push the wax further into the wire mesh...Tried and repenting!
    if this has happened with anybody, use toothbrush or wall paint brush...and do a "soft-jab and sweep"
    Ajay Ramaswamy - crwdns2934203:0crwdne2934203:0
    What do you do when you do push the wax inside? I think I pushed a substantial amount in.
    rootbeer08530 -
    toothpick just seems like a bad idea...tried the toothbrush and it worked perfectly! had a small amount of earwax build-up and I thought it was too late, as it seemed as though it had been pushed into the tiny holes in the mesh. wasn't the case!
    mitchell - crwdns2934203:0crwdne2934203:0
    tried the toothpick before I found EarSkinz (earskinz.com). I just wipe these little covers with alcohol and my EarPods are clean. i love EarSkinz bc the grill is covered. try them!
    rachael - crwdns2934203:0crwdne2934203:0
    Toothbrush works so much better, fast and easy. My EarPods sound like new so much it startled me.
    javiermatusevich - crwdns2934203:0crwdne2934203:0
    Alcohol induced corrosion? Really?
    Think again
    Michael Steinmeyer - crwdns2934203:0crwdne2934203:0
    I don't think it said that
    rootbeer08530 -
    Corrosion is possible... and more than likely. Most alcohol is not sold as 100% alcohol. It is almost always mixed in a solution with water
    tucker28 -
  3. How to clean Apple EarPods: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean Apple EarPods: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the process for the other EarPod
  4. How to clean Apple EarPods: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean Apple EarPods: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use isopropyl alcohol (rubbing alcohol) to clean the exterior of the EarPod
    • Ignore the fact that the alcohol is in the Earpods' case
  5. How to clean Apple EarPods: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to clean Apple EarPods: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't submerge the EarPods in the alcohol. If the alcohol enters the interior of the Earpod, it will damage the speaker.
  6. How to clean Apple EarPods: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the EarPods dry for at least 10 minutes before using
    • Let the Earpods dry by itself, if you use a fan, a hair dryer, or anything else, you could generate corrosion inside and that will ruin it
Remember to dry your Earpods for 10 minutes.
crwdns2935229:085crwdne2935229:0
jimenezser
crwdns2935283:008/29/12crwdne2935283:0
3 899 crwdns2915208:0crwdne2915208:0
crwdns2947412:031crwdne2947412:0
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
jaidityayadav - crwdns2934203:0crwdne2934203:0
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
allisonbridges1 - crwdns2934203:0crwdne2934203:0
With saliva? You &&^&^$ disgusting.
Pixel Shibe -
GROSS Saliva? yuck
adrienne adams -
what the &&^& is wrong with you
fisheruwu edits -
All I do is use disinfecting wipes and I home free!!!
nixoncherine - crwdns2934203:0crwdne2934203:0
doesn't enough for my earphone
Erkin Ordulu - crwdns2934203:0crwdne2934203:0
Do not use a q-tip or anything like that because the q-tip sheds - my experience with it. .
You can use a very clean toothbrush but make sure it's clean or it will leave it's own dried stuff in there -
I used a very clean toothbrush.
bekah0176 - crwdns2934203:0crwdne2934203:0
i used sticky tac to pull the excess wax out of the grill it made the grills on my earpods look like new
Walker O'Brien - crwdns2934203:0crwdne2934203:0
This is genius
Daniel Moravec -
shyte &&^&^$^ tips right there.
dannykatz - crwdns2934203:0crwdne2934203:0
I just discovered that using an earplug (y'know, the kind that you use to reduce noise) to clean my earpods is a great solution! They're made of super soft foam to conform to the small nooks/crannies of earpods and it expands back to it's regular form for next-time use. Haven't seen anything on the web about this technique - so, i thought i'd place it here.
Jose Garcia - crwdns2934203:0crwdne2934203:0
Help! i don’t have that rubbing alcohol and i don’t know where to find it. is it fine if i just use water?
아니카 Leogirl - crwdns2934203:0crwdne2934203:0
Blow them out with canned air. It works really well.
Ken Spock - crwdns2934203:0crwdne2934203:0
My headphones were so bad. I didn’t have a tooth pick but i had a needle. I carefully scrapped away all the wax then dipped my finger in rubbing alcohol and lightly tapped my finger on the speaker, then i got a q tip and rubbed it on it. I reapeted this untill it was all clean. Before all this on the right one you could only hear out of the small side speaker but now you can clearly hear out of it. I migh post a video on youtube!
Elizabeth Zeilinger - crwdns2934203:0crwdne2934203:0
I use a can of compressed air and blow my airpods out once every few weeks. It works really well.
KB Van - crwdns2934203:0crwdne2934203:0
I blow mine out with a can of compressed air. I hold the can back about 12” so as not to break anything with air pressure. It works really well so far and I have been doing it on my airpods for about 6 months.
RIP THE GRILL OUT. It saves a TON of time, and they almost never need to get cleaned again. It sounds like you will destroy them, but you won’t if you’re careful. I actually do this by jamming a Nintendo DS stylus or mechanical pencil through the grill, rotating it to the side, and using the stylus as a lever to rip it out.. There’s a white support in the center that normally prevents the grill from entering the EarPod. Try not to break it, but it doesn’t matter if you do, just angle it inward so it doesn’t poke your ear. The sound is actually better and clearer after the grill is gone. I have done this to my last 2-3 pairs of EarPods and it’s honestly the only way I’ll use them. When my cat chews through a pair, I buy/find (people lose the things all the time on the ground at my school) another set and immediately rip the grill out. I’ve never broken a pair by doing this, and when I eventually get AirPods, I will be doing this to those as well. Do it, you won’t be disappointed.
zachwalters773 - crwdns2934203:0crwdne2934203:0
None of this worked. I STILL have no sound in the left earphone. Highly disappointed.
Pixel Shibe - crwdns2934203:0crwdne2934203:0
It is possible that the speaker or wire itself is damaged. Just like with lightning cords, they are fragile and are prone to breaking easier than others.
Kelie Smith -
I used a small piece of paper, squeezed with sharp edges. Use the sharp edges for removing the strains and this a very safety, easy and a cheap method of cleaning headphones. My headphones are shining like a brand new one. ; -)
Bharath M - crwdns2934203:0crwdne2934203:0
Once I unintentionally left my EarPods in my jacket pocket. Jacket went to the washing machine. And surprisingly, EarPods were not damaged at all and got out like new. I did it again and same all clean and working fine. I would not recommend it though as from my knowledge it mus damage the metal parts in it, especially with the ones with lightning connector. I guess the best would be an ultrasonic bath.
Krikor Kouchian - crwdns2934203:0crwdne2934203:0
What about the volume switch? I opened mine up but can’t close it again
Marie Notermans - crwdns2934203:0crwdne2934203:0
Have anybody problem with the "volume" of this earpods? I clean regularly, but I notice that the volume is much low than early days.
MAXX - crwdns2934203:0crwdne2934203:0
I used rubbing alcohol to clean cord on Earbuds and it does the job!
grandmachoochoo81 - crwdns2934203:0crwdne2934203:0
I have a problem with the microphone of earpods the receptor hear me so low, what i should do. sorry for my bad english
Leider - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 238
crwdns2942667:0crwdne2942667:0 410,645
