How to calibrate gimbal on DJI Mavic Mini
crwdns2937549:0crwdne2937549:0
To reassemble your device, follow these instructions.
Arty
crwdns2935283:010/27/19crwdne2935283:0
28,150 crwdns2915208:0crwdne2915208:0
crwdns2935297:095crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Does this work for the dji mini se? As I do not see a pcode in the list.
Joshua Dockery - crwdns2934203:0crwdne2934203:0
Thank you for your video, for me it gets stuck in the "Info: The Gimbal will slowly move through all positions in all axes," and not responding.. any ideas? Thank you.
Βασίλης Τριανταφύλλου - crwdns2934203:0crwdne2934203:0
py comm_og_service_tool.py --port com pcode GimbalCalib LinearHall
Gimbal still is facing to the left
Luis Royo - crwdns2934203:0crwdne2934203:0
When I put in the py setup.py install command, I get an error message. File
not found or something similar. I’ve tried redownloading and tried different versions of py and pyserial 3.5. Any advice?
Dji mini - crwdns2934203:0crwdne2934203:0
Hi, this post from other forum helped me with this problem
Here are the steps to fix these issues:
Install setuptools: If setuptools is not installed, you can install it via pip, the Python package installer. Open your Command Prompt and run the following command: Copy this code
python -m pip install setuptools
Make sure that you have pip installed and that it is added to your system's PATH.
Check Python installation: The distutils module should be included with your Python installation. If it's missing, it suggests that there may be an issue with your Python installation. You might need to reinstall Python. Ensure that you download Python from the official Python website and install it, including the "Add Python to PATH" option during installation.
Paulius Zemaitis -
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 4,293
