How to adjust the Kinzo 8E116 quill spring
  1. How to adjust the Kinzo 8E116 quill spring, release tension: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to adjust the Kinzo 8E116 quill spring, release tension: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to adjust the Kinzo 8E116 quill spring, release tension: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 bolts that hold the spring cover in place and remove the cover.
    • When tension is lifted from the spring, the quill will fall down. Put something under the quill to prevent it from falling down all the way.
    • Turn the spring lock screw left to release the spring tension.
  2. How to adjust the Kinzo 8E116 quill spring, set tension: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to adjust the Kinzo 8E116 quill spring, set tension: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set the spring tension by turning it counterclockwise.
    • Make sure the quill is pulled up against the head frame.
    • Make sure the bolt holes end up in a position to screw the bolts back in (not directly under the switch).
    • While holding the desired spring position, tighten the lock screw.
    • Finally, place back the cover and screw the bolts back in.
knipwim
crwdns2935283:009/01/18crwdne2935283:0
12.037 crwdns2915208:0crwdne2915208:0
crwdns2935297:038crwdne2935297:0
crwdns2942667:0crwdne2942667:0 12
