How to adjust Triace A310 Brake Cable
  1. How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
  2. How to adjust Triace A310 Brake Cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you need to loosen your brakes, pull up on the arm while holding the brake cable in place.
    • To tighten your brakes follow the above step, except push down on the arm instead of pulling up.
  3. How to adjust Triace A310 Brake Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten the screw on the desired location along the cable with the same 5mm allen wrench.
You may need to repeat this process until your desired tension is achieved (trial and error).
Ben Hartinger
crwdns2935283:001/27/14crwdne2935283:0
340 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-37, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-37, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G37
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 346
