This guide will demonstrate how to wind a bobbin using a Brother LX3817 sewing machine.
Respooling a bobbin is easy with the Brother LX3817 Sewing Machine. This guide requires a plastic spool to rethread and scissors to cut excess thread between steps.
In the process of respooling, you will be working with a sewing needle attached to the machine. This needle is sharp and may cause injuries if not handled properly. Be sure to pay close attention to each step to ensure the best accuracy and least resistance is implemented.
Place the spool of thread on the spool pin.
Align the spool notch to the projection by moving it to the left.
Insert an empty bobbin spool onto the spool notch.
Cut the excess thread past the 1 inch mark.
Turn on the power button of the machine.
Lift your foot off of the pedal to stop winding.
