This guide demonstrates how to use the iFixit Soldering Splint to secure two wires for soldering.
The soldering splint jaws can hold wires up to 4 mm in diameter. It has two neodymium magnets on the bottom, allowing it to secure against ferrous surfaces. The splint is made of heat-resistant silicone.
Twist the wires together. If the wires will be under strain, consider twisting them into a Western Union splice.
crwdns2935267:0crwdne2935267:0Soldering Splint$9.95
Center the wire splice between the jaws.
Use your fingers or the flat end of a spudger to press one end of the splice into a jaw.
Press the remaining end into the other jaw.
crwdns2935267:0crwdne2935267:0FixHub | Power Series Smart Soldering Iron$79.95
Your splice is secured in place! Use your preferred tool to solder the splice.
For more soldering guides and tips, click here.
Do you have soldering questions? Check out our Answers community!
Don’t twist the wires together, clean them with IPA, tin the wires and lap solder or do a hook and loop or a lap/lash splice. David, Master IPC trainer
