How to Use the Anti-Static Wrist Strap
  1. How to Use the Anti-Static Wrist Strap, Remove any jewelry: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap, Remove any jewelry: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, remove any jewelry from your wrist and fingers.
  2. How to Use the Anti-Static Wrist Strap, Adjust the strap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap, Adjust the strap: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $7.95
    • The anti-static strap should be adjusted to fit snugly on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
  3. How to Use the Anti-Static Wrist Strap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To tighten the strap, pull the looped end away from the plastic slide.
  4. How to Use the Anti-Static Wrist Strap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
  5. How to Use the Anti-Static Wrist Strap: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
  6. How to Use the Anti-Static Wrist Strap: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the metal clip to one of the grounding nodes on an Anti-Static Mat or a grounded metal surface.
  7. How to Use the Anti-Static Wrist Strap: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're now ready to repair.
    • During your repair, be mindful of the strap's cable, as stretching it too far can cause the clip to unsnap.
For other general electronics skills guides, click here.
crwdns2935229:039crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
167,630 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,696crwdne2935297:0
crwdns2947412:07crwdne2947412:0
J'ai un doute…
Retirer tout bijou/montre/whatever, mais uniquement sur la main où l'on met le bracelet (ce qui me paraît logique) ou bien des deux mains ?
Yacou - crwdns2934203:0crwdne2934203:0
peut ton se connecter direct ex: sur une prise éléctrique avec l'embout terre de la prise
Lucka Lellig - crwdns2934203:0crwdne2934203:0
Bonjour @luckalellig non, ceci est fortement déconseillé !! Le courant des prises électriques est trop fort et risquerait de vous électrocuter.
Claire Miesch -
non la terre pas ce branche au pole positif et négatif
Si vous êtes sûre que votre prise est réellement reliée à la terre (ce n'est souvent pas le cas dans les immeubles anciens, ils peuvent une prise de terre reliée à rien) oui la fiche terre (la fiche qui sort de la prise, surtout pas les trous qui sont la phase et le neutre et qui pourraient vous électrocuter - je précise car la réponse précédente semble confondre) sera parfaite.
Marcanpilami -
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 259
crwdns2936753:030crwdne2936753:0 1,269
crwdns2942667:0crwdne2942667:0 51,382
