How to Use the Anti-Static Wrist Strap
  1. How to Use the Anti-Static Wrist Strap, Remove any jewelry: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap, Remove any jewelry: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, remove any jewelry from your wrist and fingers.
  2. How to Use the Anti-Static Wrist Strap, Adjust the strap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap, Adjust the strap: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    $7.95
    • The anti-static strap should be adjusted to fit snugly on your wrist.
    • Pull up on the looped end of the strap to disengage the plastic lock.
  3. How to Use the Anti-Static Wrist Strap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To tighten the strap, pull the looped end away from the plastic slide.
  4. How to Use the Anti-Static Wrist Strap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To loosen the strap, pull the main part of the band away from the plastic slide.
    • Re-engage the plastic lock before continuing.
  5. How to Use the Anti-Static Wrist Strap: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the strap over your hand and secure it to your wrist.
    • If the strap is still too loose or tight, you can adjust it while it's on your wrist.
  6. How to Use the Anti-Static Wrist Strap: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use the Anti-Static Wrist Strap: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach the metal clip to one of the grounding nodes on an Anti-Static Mat or a grounded metal surface.
    What qualifies as a grounded metal surface?
    Henning Sprang - crwdns2934203:0crwdne2934203:0
  7. How to Use the Anti-Static Wrist Strap: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You're now ready to repair.
    • During your repair, be mindful of the strap's cable, as stretching it too far can cause the clip to unsnap.
For other general electronics skills guides, click here.
crwdns2935229:039crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
167.972 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.861crwdne2935297:0
crwdns2947412:07crwdne2947412:0
J'ai un doute…
Retirer tout bijou/montre/whatever, mais uniquement sur la main où l'on met le bracelet (ce qui me paraît logique) ou bien des deux mains ?
Yacou - crwdns2934203:0crwdne2934203:0
peut ton se connecter direct ex: sur une prise éléctrique avec l'embout terre de la prise
Lucka Lellig - crwdns2934203:0crwdne2934203:0
Bonjour @luckalellig non, ceci est fortement déconseillé !! Le courant des prises électriques est trop fort et risquerait de vous électrocuter.
Claire Miesch -
non la terre pas ce branche au pole positif et négatif
Si vous êtes sûre que votre prise est réellement reliée à la terre (ce n'est souvent pas le cas dans les immeubles anciens, ils peuvent une prise de terre reliée à rien) oui la fiche terre (la fiche qui sort de la prise, surtout pas les trous qui sont la phase et le neutre et qui pourraient vous électrocuter - je précise car la réponse précédente semble confondre) sera parfaite.
Marcanpilami -
On step 6 it is said to attach the wrist to a grounding nod of the mat.
Which is this nod on an ifixit mat?
Is it safe to ground the mat and the wrist at different outlets in the same time?
padrobo - crwdns2934203:0crwdne2934203:0
i don't have a metal grounding pillar/leg or an anti-static mat like in the images. how else can i try to use the anti-static wristband?
amelie shop - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 36
crwdns2936753:07crwdne2936753:0 260
crwdns2936753:030crwdne2936753:0 1,219
crwdns2942667:0crwdne2942667:0 51,653
