How to Use a Desoldering Pump
  1. How to Use a Desoldering Pump, Prime the pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use a Desoldering Pump, Prime the pump: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Desoldering Pump
    $3.99
    • If this is your first time using a desoldering pump, try priming and activating the pump a few times before you use it for desoldering purposes.
    • Firmly grasp the desoldering pump with your hand.
    • Depress the plunger until it locks in place.
    • This primes the spring-loaded piston for suction.
  2. How to Use a Desoldering Pump, Activate the pump: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use a Desoldering Pump, Activate the pump: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To activate the pump, press the black side button.
    • This releases the spring-loaded piston, which creates a burst of suction at the nozzle.
    • The piston release creates a substantial kickback. Brace your hand when you use the pump to keep the nozzle steady.
  3. How to Use a Desoldering Pump, Desolder a joint: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Desolder a joint: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Desolder a joint: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Solder Wick Braid
    • Do not use the desoldering pump to desolder joints near small surface-mounted (SMT) components. The heat spillover and suction may dislodge the SMT components.
    • Prime the desoldering pump by depressing the plunger.
    • Heat the solder joint until the solder is liquified. To help with heat transfer, add some solder onto the soldering iron's tip.
    • Position the pump's nozzle as close to the molten solder as possible.
    • The nozzle is made of heat-resistant plastic, so don't worry if you occasionally brush the tip with it.
    • Press the side button to activate the pump.
    • Repeat the process until the joint is clean. You can also use solder wick to help soak up any remnant solder.
  4. How to Use a Desoldering Pump, Clean the desoldering pump: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Clean the desoldering pump: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Desoldering Pump, Clean the desoldering pump: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To clean the pump, prime and activate the pump a few times. This pushes a rod through the nozzle and ensures that solder doesn't block it.
    • On the rare occasion when the pump needs a more thorough cleaning, you can disassemble the pump to clean it out:
    • Grasp the nozzle by its knurled edge.
    • Twist the nozzle counter-clockwise to unscrew it. This may be difficult due to a tight-fitting O-ring.
    • Remove the nozzle and clean out the pump interior.
    I hadn’t used my pump for a while so it wasn’t zooming up the tube like it used to (despite numerous tries). So, I simply unscrewed the nozzle and dripped a bit of fine oil into the tube. I replaced it and operated it a couple of times…BINGO….best it ever worked. I was totally surprised and glad I didn’t have to buy a replacement. BTW - I happened to have some Starrett tool oil on hand and that’s what I used. Any thin oil should be fine and you don’t need very much.
    Keith Piercey - crwdns2934203:0crwdne2934203:0
    That’s a great tip Keith!
    Arthur Shi -
    What is the best way to clean sthe older with when it is in the pump?
    Jack Albertelli - crwdns2934203:0crwdne2934203:0
For soldering instructions and tips, follow this guide.
crwdns2935229:074crwdne2935229:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
288.905 crwdns2915208:0crwdne2915208:0
crwdns2935297:0613crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:020.935crwdne2935297:0
Good review, but I’ve found that these small solder suckers don’t do a very good job. The much larger “Soldapult” (https://www.edsyn.com/product/DS017.html) provides much more suction and can often completely clear a joint in one use.
shamino - crwdns2934203:0crwdne2934203:0
Apply higher temperature on your soldering iron, above 380°C.
Use bigger tip, bigger heating surface provides more effecitive heat transfer.
SchwarzeKatz -
If you are asking about why the tip of the solder sucker doesn't melt, it is made of a heat resitant material. Notice the word resistant.
Budda Belly - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 81
crwdns2936753:07crwdne2936753:0 491
crwdns2936753:030crwdne2936753:0 2,411
crwdns2942667:0crwdne2942667:0 93,112
