If the single-pivot caliper brakes on your Schwinn Solara bicycle are creating a grinding noise when they brake, if there is shaking of the wheel during braking, or decreased responsiveness to pressure on the brake pedal, they require tuning. Brake tuning is necessary to account for wear on the drum and lining that happens when the brake system is used. It is important to take caution during disassembly by following appropriate techniques to ensure a proper repair.
Set bike up on bike stand or have someone hold onto the bike, keeping it balanced.
Pull on brake levers so that the brakes pads are touching the edge of the rim.
Using a 10 mm wrench, back out of the barrel adjuster on the brake calipers 2-3 turns.
With the same 10 mm wrench, loosen the pinch bolt at the bottom of brake caliper to release the brake wire.
With the 10 mm wrench, loosen the bolt connecting the brake caliper to the frame of the bicycle.
Adjust the brake caliper so that it is centered with the tire and rim. Tighten bolt back up when finished.
Take the 10 mm wrench and loosen the bolt on the back side of the brake pad.
Adjust the brake pads position on the rim by sliding it up and down along the surface of the rim until it is centered.
When finished, tighten the bolt for the brake pad back up to hold its position.
Pull on the the brake lever to adjust the pad clearance from the brake line.
Tighten the barrel adjuster at the brake caliper.
crwdns2917034:0crwdne2917034:0
How do u fix the mounting bolt to the front caliper that connects brake to bike that bolt where do I get one
