This guide shows you how to troubleshoot and fix your Whirlpool electric oven that is not heating. It includes steps for checking power, testing the heating element, examining the control board, and addressing other possible causes. It also includes tips for distinguishing between electric and gas oven issues and preventing future heating problems.
crwdns2931653:01crwdne2931653:0 Distinguish electric vs gas oven issues
Confirm your model is electric if it uses a heating element rather than a gas igniter.
crwdns2931653:02crwdne2931653:0 Check burner functionality
Restore power and turn on a couple of stovetop burners to see if they function.
Confirm that at least one burner effectively produces heat to verify 240 volt supply.
crwdns2931653:03crwdne2931653:0 Inspect the oven element
Examine the entire visible portion of the heating element for breaks or signs of damage.
crwdns2931653:04crwdne2931653:0 Remove the element for testing
Unscrew the two mounting screws at the rear of the oven securing the element.
Gently pull the element forward so the connector wires remain accessible.
crwdns2931653:05crwdne2931653:0 Test the element with a multimeter
Set the multimeter to measure resistance in ohms.
Place one lead on each element terminal and wait for a stable reading.
Confirm a typical reading between 20 and 40 ohms to show a healthy element.
Reinstall the element with the mounting screws and reconnect any wires securely.
crwdns2931653:06crwdne2931653:0 Inspect the terminal block
Unscrew and remove the cover plate to reveal the terminal block where the power cord connects.
Look for any melting, burning, or looseness on the main voltage terminals.
crwdns2931653:07crwdne2931653:0 Check voltage at the terminal block
Use the multimeter to measure from L1 to neutral and from L2 to neutral for around 120 volts each.
Measure from L1 to L2 to verify about 240 volts for a proper power supply.
crwdns2931653:08crwdne2931653:0 Access and examine internal back panel
Remove all screws holding the large back panel and detach it to see the oven’s internal components.
Check for a thermal fuse if present and test it for continuity if the oven has self-cleaning features.
Inspect for a hidden bake element or a convection fan element if your model has one.
Reattach the panel with all screws once checks are complete.
crwdns2931653:09crwdne2931653:0 Check the thermostat sensor
Locate the thermostat probe near the top or rear of the oven cavity.
Disconnect the sensor wiring and set the multimeter to measure ohms.
Expect around 1050 to 1100 ohms at room temperature for a typical sensor.
crwdns2931653:010crwdne2931653:0 Evaluate the control board
Disconnect power and visually check the board for burn marks or cracked components.
Replace the board if all other components test good and no voltage is supplied to the element.
crwdns2931653:011crwdne2931653:0 General maintenance tips
Keep the oven interior clean to reduce stress on heating elements and sensors.
Avoid slamming the oven door to prevent loosening of internal connections.
Inspect the power cord and outlet periodically for signs of wear.
Testing each component helps isolate why your Whirlpool electric oven will not heat. Replacing the faulty part restores proper function. If you are ever unsure or uncomfortable with electrical work, consult a professional for safety.
Thank you, clear and easy, you're great!!!
