The rear wheels of the wheelchair are used for propelling. This guide will show users how to tighten the main wheels on the GEN 2 wheelchair. The process is simple and only requires one tool.
Inspect the chair to see which wheel is loose.
Tighten the outer bolt with a 19 mm socket wrench.
Tighten the nut facing the inside of the chair with a 19 mm wrench.
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
