This guide will show how to restore a damaged corkboard that may have holes or tears in it. This fix can be used on any size board. It can be especially useful for boards that are mounted on a wall and are expensive to replace.
Cover your work surface with a tarp.
Use a rag, soap, and water to scrub the damaged area to remove residual pieces of cork and glue.
Allow the area to dry.
Apply wood filler liberally on top of the holes.
Smooth out the wood filler using a putty knife.
Hold the putty knife at an angle and use long strokes to flatten the filler as much as possible.
Wait 1 hour for the filler to dry.
Use 80-grit sandpaper to sand down the excess filler in a circular motion.
Cover the damaged area with a thin, even layer of wood sealant.
This guide will help you keep your old cork boards instead of trying to replace them. I hope you found our guide useful.
