How to Restore Synthetic Wig Quality
  1. How to Restore Synthetic Wig Quality, How to Restore Synthetic Wig Quality: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fill your container of choice with warm to hot water (enough to cover the entire wig).
  2. How to Restore Synthetic Wig Quality: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To make sure your wig is fully moisturized, add shampoo before and after putting the synthetic wig in the container.
    • Apply the hair shampoo of your choice into the container.
    • If using a bottle with a pump, apply 5-7 pumps of shampoo to the water. If using a squeeze bottle, count to 5 seconds while pouring shampoo into the water.
    • Mix shampoo into the water thoroughly.
  3. How to Restore Synthetic Wig Quality: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the synthetic wig into the container
    • Make sure the wig is completely under water.
  4. How to Restore Synthetic Wig Quality: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If using a bottle with a pump, apply 5-7 pumps of shampoo to the water. If using a squeeze bottle, count to 5 (seconds) while pouring shampoo into the water.
    • Mix shampoo into the water to clean and moisturize the wig thoroughly.
    • Leave the synthetic wig in the container for 15-20 minutes. The longer you leave it in, the softer your wig will be.
  5. How to Restore Synthetic Wig Quality: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rinse the shampoo from the synthetic wig with warm water from the bottom to the top.
  6. How to Restore Synthetic Wig Quality: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Comb or brush through your synthetic wig to remove knots and tangles, from the bottom to the top.
    • For straight hair synthetic wigs: you can use a small-tooth comb or hair detangler brush.
    • For wavy to loose curl synthetic wigs: you can use a wide-tooth comb or hair detangler brush.
    • There should be no restriction after a full comb or brush through.
  7. How to Restore Synthetic Wig Quality: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dump the old water from the container and fill it with fresh, warm to hot water.
  8. How to Restore Synthetic Wig Quality: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Add the synthetic wig back into the fresh water in your container. Apply the hair conditioner of your choice into the container.
    • To make sure your wig is fully moisturized, add conditioner before and after putting the synthetic wig in the container.
    • If using Silicon Mix, apply 2-3 spoonfuls into the water.
    • If using a bottle with a pump, apply 5-7 pumps of conditioner to the water.
    • If using a squeeze bottle, count to 5 (seconds) while pouring the conditioner into the water.
    • Mix conditioner into the water to moisturize the wig thoroughly.
    • Leave the synthetic wig in the container for 20-30 minutes. The longer you leave it in, the softer your wig will be.
  9. How to Restore Synthetic Wig Quality: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rinse the conditioner or Silicon Mix from the wig with warm water from the bottom to the top.
    • Ring out excess water from your wig.
    • Do one last comb or brush through to make sure there are no more tangles or knots in the wig.
    • Pat dry with a soft microfiber towel.
  10. How to Restore Synthetic Wig Quality: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Restore Synthetic Wig Quality: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply the wig to the mannequin head.
    • Using pins can keep the wig secure through the drying process.
    • Leave wig on the mannequin head to dry for one day.
    • For immediate use of wig, dry with hair dryer on medium to low heat.
    • For straight hair synthetic wigs: dry it normally.
    • For synthetic wigs with wavy to loose curls: the curl pattern should return after drying. For more security, add curlers to the hair, following the curl pattern, while drying.
  11. How to Restore Synthetic Wig Quality: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the drying process, your synthetic wig should look good as new!
    • For maximum shine and hold, add hair spray after drying.
    • For straight synthetic wigs: if you are experiencing any small hairs that are sticking out after the drying process, use a flat iron on medium to high heat.
    • For wavy or loose curl synthetic wigs: if you are experiencing any small hairs that are sticking out after the drying process, use a curling iron (or flat iron) on medium to high heat and follow the curl pattern of the wig.
  12. How to Restore Synthetic Wig Quality: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before
  13. How to Restore Synthetic Wig Quality: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After
Shamia Tisdale
crwdns2935283:010/05/22crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 14-14, Friess Fall 2022 crwdns2935289:0University of North Texas, Team 14-14, Friess Fall 2022crwdne2935289:0
UNT-FRIESS-F22S14G14
crwdns2936753:07crwdne2936753:0 56
crwdns2936753:030crwdne2936753:0 165
crwdns2942667:0crwdne2942667:0 4,671
