How to Reset the SMC on MacBooks
    • These MacBooks have a T2 security chip:
    • MacBook Air introduced in 2018 or later
    • MacBook Pro introduced in 2018 or later
    • If it has a T2 chip you can reset the SMC as follows (if not, skip this step):
    • Hold the "Control" and "Option" (Alt) on the left side of your keyboard and the "Shift" on the right side of your keyboard for 7 seconds.
    • Then additionally press and hold the power button and keep holding all four keys for another 7 seconds, then release them.
    • Press the power button after few seconds to turn on your MacBook.
    • These models have a non-removable battery (per Apple definition):
    • MacBook Pro (Early 2009) and later
    • all models of MacBook Air
    • MacBook (Late 2009)
    • MacBook (Retina, 12-inch, Early 2015) and later
    • Proceed with the next step to reset your SMC.
    • For other models skip this and the next step.
    • Shut down your Mac.
    • Unplug the MagSafe or USB-C power adapter from your computer.
    • Using the built-in keyboard, press Shift-Control-Option on the left side of the keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
    • Release all keys.
    • Reconnect the power adapter.
    • Press the power button again to turn on your Mac.
    • Disconnect the MagSafe power adapter from your computer.
    • Remove the battery.
    • Press and hold the power button for 15 seconds.
    • Reconnect the battery and MagSafe power adapter.
    • Press the power button to turn on your Mac.
    • The LED on the MagSafe power adapter might change colors or temporarily turn off when you reset the SMC.
The SMC of your MacBook has now been reset.
crwdns2935229:034crwdne2935229:0
mikeyd123
crwdns2935283:004/04/18crwdne2935283:0
897 crwdns2915208:0crwdne2915208:0
Il mio MacBook Pro 2019 nuovo di 3 mesi non vuole accendersi.
Ieri sera con la batteria 1% ho spento il mac. Stamattina non vuole avviarsi, non da segni di vita.
Il mac fa solo un suono quando attacco il caricatore, poi nulla. Dopo 2 ore in carica niente.
Cosa mi consigliate?
Grazie
Mario Scotti - crwdns2934203:0crwdne2934203:0
merci ! fonctionne parfaitement depuis ?
David Derisoud - crwdns2934203:0crwdne2934203:0
Mahalo, mikeyd123!
I just purchased a refurbished MBP 15 (11,5) mid-2015 Retina, macOS 12.2.1, and was having an issue with the fan running non-stop, from boot-up to shut-down. Resetting the SMC seems to have addressed the fan issue. Hopefully there are no thermal issues. If there are, iʻll check back in.
Kahana - crwdns2934203:0crwdne2934203:0
I have this same model and am
Having the same issue but I can’t figure out which sequence of buttons! Please advise!
Gerene Townsend -
I followed the reset instructions for my MacBook Retina 2017 (A1534) but now I get a Recovery Assistant & I'm asked to rest my password. I don't need to reset my password, I just want to reset to factory settings because a new owner will use this MacBook.
Ivana Sifuentes - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 129
crwdns2936753:07crwdne2936753:0 785
crwdns2936753:030crwdne2936753:0 3,663
crwdns2942667:0crwdne2942667:0 271,084
