This repair guide is necessary for all makeup lovers to preserve their favorite products and save money. As a makeup lover, it is devastating when you break a product. You would first assume you should throw it away and need to purchase a new one. But makeup is also very expensive now. Learning how to repair your broken compact makeup will lessen waste, save money, and allow for continual use of the product. This repair is applicable for powder products such as bronzer, blush, eyeshadow, highlighter, setting powder, and powder foundation.
If some of the product remains unbroken, break it down using a toothpick . Completely crush the powder for a smooth fix.
Add a few drops of rubbing alcohol to the broken product (the amount differs based on how much product you have left) and then thoroughly mix the alcohol into the powder with a toothpick.
Place plastic wrap over the product and pull taut to reduce wrinkles in the plastic wrap.
Press and smooth the product out using your finger or a spoon.
Once smoothed, remove the plastic wrap and allow the compact to dry for 6-8 hours.
Lastly, enjoy your product! It provides the same pigment and performance as it once did before the break.
This method will save you money and preserve your favorite powder products without compromising its quality or pigment. I hope you found my guide useful.
Your friendly makeup lover,
Alexis
