How to Replace the Trigger Spring of a Spray Bottle
Chanelle Abi Najem
crwdns2944107:0crwdnd2944107:0Chanelle Abi Najemcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 14, 2025crwdne2944111:0
2 - 3 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
A spray bottle has a simple function, yet it could have an outstanding value, if a user follows these methods to repair select parts around the head of the bottle. A spray bottle’s routine use around the household is critical because a typical person can entertain plenty of functions for this spray bottle. While using a spray bottle, the wear and tear will accumulate, thereby subjecting the bottle to broken and dislodged pieces.
     This guide is essential to standard spray bottle users who require fixing and replacing the trigger spring item. Instead of abandoning the whole spray bottle over one displaced item, which is commonplace and a burden—fix it, as presented.
Tip: You can choose to leave the bottle head screwed or unscrew it, whichever is easier for you!
Caution: This repair uses small pieces that are choking hazards for small children and animals.
  1. How to Replace the Trigger Spring of a Spray Bottle, Trigger Spring: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle, Trigger Spring: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle, Trigger Spring: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly and gently spread the plastic head so you can easily slide out the trigger lever to access the remaining parts.
    • Be careful not to push too hard when holding the plastic open to avoid finger injury or product breakage.
  2. How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After separating the trigger lever from the rest of the bottle, place the spring into the opening slot.
    • You can alternatively start by connecting the larger opening of the smaller plastic part with the spring.
  3. How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently but firmly push in the smaller plastic slot.
  4. How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the longer plastic piece, ensuring that the small gap splitting one end of the piece is horizontally facing out.
  5. How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the outlined plastic part into the bottle head, ensuring that all sides are inside the head and parallel to the bottom plastic part.
    • Confirm that the line in the middle of the trigger lever aligns with the gap in the previously attached plastic part.
  6. How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the first protruding piece into its respective opening, then carefully pop the other side in.
    • Maintain the center pieces' alignment when reconnecting to ensure functionality.
  7. How to Replace the Trigger Spring of a Spray Bottle: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test your final assembled product.
Chanelle Abi Najem
crwdns2935283:002/06/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
York University, Team 1-4, Morris Winter 2025 crwdns2935289:0York University, Team 1-4, Morris Winter 2025crwdne2935289:0
YORK-MORRIS-W25S1G4
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 150
