Follow this guide if you need to replace the string of your Rogue RM-100A A-Style Mandolin. The Mandolin is a stringed instrument and occasionally the strings may wear out or snap. With this step-by-step guide, you will learn how to restring your instrument so you can continue playing your favorite music in no time!
Lay the Mandolin face up on a flat surface.
Start at the headstock of the Mandolin, and unwind the wire string by turning the tuning peg in a clockwise rotation until it becomes loose and easy to remove.
At the tailpiece of the Mandolin, use both of your thumbs to apply pressure to push the tailpiece cover away from you.
Remove the string you are replacing from the tailpiece.
Insert the new string loop onto the hook.
Pull the string up along the bridge onto the fretboard until it reaches the headstock.
Insert the string into the hole of the tuning post all the way through.
Loosen the hold of the string.
Turn the excess string to the left and pull it under the string.
Again, pull the excess string up and over to the left.
Pull the knot.
Twist the tuning pegs in a counterclockwise rotation.
Place the tailpiece back by sliding it towards the headstock.
