If you need to replace the propane tank in your Toyota Forklift Truck (Model: 8FGCU15), follow this guide.
This style of forklift is quite common in warehouses, and the gas tanks frequently run dry. This is an OSHA compliant step by step guide to safely replace an empty propane tank.
While changing the tank, you will need to wear the the appropriate Personal Protective Equipment (PPE). Please be sure to acquire a pair of goggles and a pair of propane resistant gloves before beginning this project.
Put the shifter in neutral, turn the engine off, and engage the emergency brake.
Put on the gloves and goggles.
Turn the shut off valve clockwise to close the empty tank.
Disconnect the truck’s gas hose from the tank’s forklift adapter.
Look at the rack securing the tank to the truck.
Push in the latch on the left-hand side while simultaneously pulling the entire rack back towards you.
Release the latch holding the tank to the rack.
Position the new tank in the rack so that the forklift adapter is facing away from you.
If needed, rotate the latch clockwise/counterclockwise before closing to loosen/ tighten the latch.
Carefully screw the gas hose onto the forklift adapter.
Once you are sure the connection is secure, turn the shut off valve counterclockwise to open the tank.
If done properly, there should be no drips or hissing, and little to no smell of propane. The engine should start at once.
crwdns2917034:0crwdne2917034:0
Step 11a rotate the tank so the pin and small round hole align (facing downward). The pressure relief valve must face upwards.
In case of exposure to high heat or flame the pressure relief valve will release excessive pressure.
