How to Replace the Headlight in a 2010-2014 Volkswagen Jetta
  1. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the ignition fully off and open the hood of your vehicle.
    • The lever to open it is on the left hand side of the pedals. It’ll make a noticeable clunk sound when pulled the first time which releases the first of the two step hood opening procedure.
    • Make your way to the front of the car and push up on the lever underneath the hood to fully open the hood.
    • Use the hood prop rod to hold the hood open for the duration of the repair.
  2. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the plastic dust cover behind the burnt headlight and gently remove it. If the cover is stuck, you can use a screwdriver to pop it out.
  3. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the cover is off, twist the light harness from the fixture in a counter clockwise rotation.
    • Pull the bulb to separate it from the connector.
    • Insert the new bulb in the correct orientation as the previous, and tighten it back into the headlight by rotating it clockwise.
  4. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reapply the dust cover and close the hood of the vehicle.
  5. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the ignition on and switch on the lights to test the new working headlight.
To replace the other headlight. follow the same instructions.
Seyed-Mohammad Hosseiny
crwdns2935283:009/22/20crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
Am I missing something? Or is there a trick to those tabs to release the bulb?
Dez Petrovic - crwdns2934203:0crwdne2934203:0
They are a pull to release mechanism. no need to undo tabs.
Seyed-Mohammad Hosseiny -
Don’t forget to wear gloves when handling halogen light bulbs!
Where’s the driving lights?
Ted Stoffers - crwdns2934203:0crwdne2934203:0
I installed the new bulb but it still doesn’t work. My neighbor, a retired mechanic came to help and undid both and put back and now, both headlights don’t work. Any other advice?
Emilia Lievano - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 104
crwdns2936753:030crwdne2936753:0 410
crwdns2942667:0crwdne2942667:0 29,300
