If the key fob for your 2019 Ford Fiesta has stopped working, the likely culprit is a dead battery. This guide will show you how to replace the battery of your 2019 Ford Fiesta key fob.
The 2019 Ford Fiesta is a part of the seventh generation of this line of Ford subcompact cars. It is an easy process and no prior repair experience is necessary.
Use a washer or opening tool in the gap on the right-hand side of the key fob to pry the top case off of the fob.
Work your way around the edge of the fob with the opening tool to release the clips of the case.
After separating the key fob, you'll see the battery on the side of the fob with the key attached.
Use an opening tool to pry the battery out of the key fob.
Place the cover back on the fob and snap it into place. Once you hear the click, the repair is complete!
