Replacing the battery in a Kwikset Home Connect 620 Smart Lock is a straightforward process that most people can accomplish at home.
This process presents little opportunity for injury. Even the most novice DIY-er should have no problems following the instructions and performing the repair.
Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
Left side
Right side
Bottom
Remove the faceplate from the lock mechanism by pulling straight out.
Remove the battery pack from the lock mechanism by pulling straight up.
Remove the batteries from the battery pack.
Insert new batteries into the battery pack.
Insert the battery pack back into the lock mechanism by pushing straight down.
Reattach the faceplate to the lock mechanism by pushing straight in.
Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
Bottom
Right side
Left side
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
