How to Replace Vintage Quilt Patch
  1. How to Replace Vintage Quilt Patch, Quilt Patch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch, Quilt Patch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch, Quilt Patch: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by identifying the damaged patch to be replaced.
    • Measure the area to be replaced, in this case, a square.
    • Make sure to measure from where the patch to be replaced is sewn to the neighboring patches.
  2. How to Replace Vintage Quilt Patch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay down the fabric that will be used for the replacement patch.
    • Measure the shape for the new patch on the replacement fabric. Be sure to measure the new patch a little larger than the existing patch so the edges can be folded under and there's less room for error.
    • In this example, the patch being replaced is a 2" square. The new patch that's cut out will be a 3" square.
    • Place dots with a pencil to notate where the new patch's corners are as guides to be cut between.
    • A line could be drawn between the dots, if needed.
  3. How to Replace Vintage Quilt Patch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use fabric scissors to cut between the dots made in the previous step.
    • Cut in as straight a line as possible but since the new patch will be a little larger than the existing square, it's ok if it's not completely straight.
    • Or, as mentioned in Step 2, lines can be drawn between the dots if the straightness of the cuts is an issue.
  4. How to Replace Vintage Quilt Patch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the new patch is cut out of the fabric, place dots with a pencil where the edges will be folded under to notate the new square.
    • In this example, 0.5" is being taken off of each side to make the resulting square 2" once the edges are folded under.
  5. How to Replace Vintage Quilt Patch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fold all four edges in where the dots were placed in Step 4.
  6. How to Replace Vintage Quilt Patch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new replacement patch over the existing patch on the quilt to make sure it fits and covers everything that needs to be covered.
    • The patch should cover the damaged patch and have a little extra area so it can be sewn to the neighboring patches on the quilt.
  7. How to Replace Vintage Quilt Patch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pin the new patch to the quilt so when you start sewing it stays in place.
    • On one corner of the new patch, take a straight pin or additional sewing needle and go down through the new patch out the back side of the quilt.
    • Then take pin back up through the back side of the quilt and through the top side of the quilt. The pin should be holding new patch to the quilt now at that spot.
    • Repeat the above steps with three additional pins on three corners of the new patch.
  8. How to Replace Vintage Quilt Patch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the end of the thread and tie a knot.
    • Tie three or four additional knots over the first knot to make it a little larger and ensure it won't slip through your fabric. You want to make sure the thread will stop when sewing.
    • Try to make the knot as close to the end of the thread as possible but if there's a lot of extra on the end, it can be snipped off with the scissors.
  9. How to Replace Vintage Quilt Patch: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull a good amount of thread off the spool. In this example, about 1.5 feet of thread was pulled, which is substantially more than was needed. Depending on the size of the patch, you may need more or less thread.
    • Cut the thread. Be careful working with fabric scissors that are extremely sharp.
    • Take the end of the thread without the knot in it and put it through the eye of the needle.
  10. How to Replace Vintage Quilt Patch: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now the patch is ready to be sewn on. Take your needle and thread and come up through the back side of the quilt at the edge of the new patch.
    • Coming through the back side of the quilt will ensure the knot in the thread is not visible from the top of the quilt.
    • Pull the thread taut.
  11. How to Replace Vintage Quilt Patch: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move 0.25" or 0.5" down the new patch from where you just pulled the thread through the new patch. Then take the needle down through the neighboring patch and through to the back of the quilt.
    • Repeat the steps above. Push the needle up through the back of the quilt and through the new patch. Keep maintaining the 0.25" or 0.5" distance between stitches.
    • Continue in this way around all the edges of the new patch: going down through the neighboring, existing patch then up through the back of the quilt and surfacing through the new patch.
  12. How to Replace Vintage Quilt Patch: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once all edges of the new patch are sewn down, push one final stitch down through the top of the quilt.
    • On the back side of the quilt tie a knot in the thread. Repeat the knot tying done in Step 7 and tie three or four additional knots over your first knot to ensure it's large enough to not be pulled through the quilt.
  13. How to Replace Vintage Quilt Patch: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace Vintage Quilt Patch: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the thread off after the knot you tied in Step 12.
    • Try to leave as little room between the knot and the quilt as possible so, there's less risk of it getting snagged.
katie parks
crwdns2935283:009/17/23crwdne2935283:0
250 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 22-7, Watkins Fall 2023 crwdns2935289:0Austin Community College, Team 22-7, Watkins Fall 2023crwdne2935289:0
AUSTINCC-WATKINS-F23S22G7
crwdns2942667:0crwdne2942667:0 306
