This fast fix will help guide users through the process of removing a light bulb from a Spice Lab Himalayan Crystal Salt Lamp and replacing it. This specific guide uses an E12 light bulb, but other models from other companies could use different bulbs and be constructed in a different manner. Be sure to check your specific brand and model for additional details that could require additional steps.
Rotate the power switch in the counterclockwise direction to halt electricity flow to the lamp.
Be sure to unplug the lamp to mitigate risk.
Wait 5-10 minutes to allow the bulb to cool before continuing.
Flip the lamp so that the base is accessible.
Using your hands, pull the black circular light fixture out of the salt lamp.
Using your fingers, twist the light bulb in the counterclockwise direction to remove the bulb.
Screw an E12 light bulb into the empty socket.
Hopefully this fix has reinvigorated your salt lamp. Thank you for using our guide
crwdns2917034:0crwdne2917034:0
replacing salt lamp bulb is not a big deal , but finding a good salt lamp bulb which lasts long is hard
