How to Replace Pants Pockets
  1. How to Replace Pants Pockets, Pocket: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets, Pocket: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets, Pocket: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the damaged pocket lining out so you can see where it attaches to the pants.
    • Use sewing scissors to cut along the edge of the pocket while keeping it intact.
    • Remove the cutout pocket and keep it for the next step.
  2. How to Replace Pants Pockets: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully cut along the stitched edge of the pocket.
    • Lay the pocket out flat on the table.
  3. How to Replace Pants Pockets: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the cutout of the old pocket over the fabric you're using for the new pocket.
    • Use a ruler to measure half an inch around the pocket’s edges to allow room for sewing the seam.
    • Use a fabric marker or chalk to trace around the pocket.
    • Ensure the outline is clearly visible to help guide the cutting or sewing process.
  4. How to Replace Pants Pockets: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use sewing scissors to cut along the outline you've drawn.
  5. How to Replace Pants Pockets: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you’re not familiar with how to thread a needle, please refer to this video How to Thread a Needle. It provides clear, beginner-friendly instructions to help you get started.
    • Fold the new fabric in half.
    • Begin stitching at the corner of the edge.
  6. How to Replace Pants Pockets: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the needle through the edge of the fabric, pulling it through until there’s a small length of thread left on the other side.
    • Create a small loop by bringing the needle back through the fabric near the same spot.
    • Pull the thread gently but firmly to tighten the loop.
    • Continue stitching along the edge, spacing each loop about ¼ inch apart to create a strong hold.
    • Keep your stitches close together to prevent gaps and make the pocket more durable.
  7. How to Replace Pants Pockets: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you’ve finished stitching the edge, create a final loop, just like tying a shoelace.
    • Pass the needle through the loop and pull it tight to form a knot.
    • Repeat the knot at least once more to ensure it stays secure.
    • Use scissors to carefully trim the extra thread, leaving about ¼ inch to prevent the knot from unraveling.
  8. How to Replace Pants Pockets: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the new pocket fabric inside the pants, positioning it where the original pocket was removed.
    • Make sure the fabric is evenly spread out and flat to avoid wrinkles or bunching.
    • Compare the position of the new pocket with the other pocket and the original stitch marks, to ensure it's placed correctly.
    • If you're unsure about the placement, use the cut-out pocket as a reference.
    • Use sewing pins or clips to temporarily hold the fabric in place while you prepare to sew.
  9. How to Replace Pants Pockets: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Pants Pockets: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the needle through the pants fabric and the new pocket fabric, starting at one corner.
    • Follow the same stitching method from Step 6, creating small, even loops around the edge of the pocket.
    • Continue stitching along the entire edge, keeping your loops about ¼ inch apart for durability.
    • Make sure the needle goes through both layers of fabric each time to fully secure the pocket.
  10. How to Replace Pants Pockets: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue stitching until the new pocket is connected to the pants.
    • Once finished, gently tug along the edge to check that the stitches are secure and evenly tightened.
    • If any areas feel loose, go back and reinforce them using the same stitching method.
    • Remove any sewing pins or clips still holding the pocket in place to avoid injury.
    • Give the pocket a final check for alignment, strength, and comfort.
    • A second round of stitching around stress points (like corners) can add extra durability.
  • If your new pocket feels loose, repeat Steps 6 and 7 to reinforce the stitching.
  • Take your time with the finishing touches to ensure the pocket is securely attached.
Lucca Sa
crwdns2935283:001/31/25crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
York University, Team 3-11, Woodhouse Winter 2025 crwdns2935289:0York University, Team 3-11, Woodhouse Winter 2025crwdne2935289:0
YORK-WOODHOUSE-W25S3G11
crwdns2936753:030crwdne2936753:0 93
crwdns2942667:0crwdne2942667:0 529
