How to Replace Broken Deck Boards on an Outdoor Patio
  1. How to Replace Broken Deck Boards on an Outdoor Patio, Broken Deck Boards: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect the damage and mark any broken boards that need to be replaced using painter's tape.
  2. How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Measure and estimate the new boards you need to purchase.
    • We recommend using treated 5/4-inch x 6-inch lumber that you could easily get from any home improvement stores.
  3. How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the broken boards.
    • If your boards were originally put down with screws, then remove the old screws with a drill.
    • If your boards were originally affixed with nails, pry the nails up before removing the boards.
    • It's generally recommended to take a more gentle approach, otherwise you may destroy the joists.
  4. How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check and sweep the joists.
    • In most cases, deck framing typically takes a lot longer to deteriorate because it is protected from the sun, wind, and rain by the boards above it. So joists should be in good shape.
  5. How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Measure the replacement pieces.
    • Put the broken board on the new board and mark the angle it should be cut at on both sides.
    • Draw the line by connecting the marked points.
  6. How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a hand saw to cut along the marked cutting line for each new board.
    • A circular saw is recommended to expedite the process if there are many broken deck boards to be replaced.
  7. How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mark up screws position on each new boards.
    • Line up the boards and mark the length where the screws should go.
    • Measure the position of the screws from the edge on the old boards and mark the same position on the new boards.
  8. How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace Broken Deck Boards on an Outdoor Patio: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pre-drill the holes at the marked spots using a 1/8th inch drill bit.
    • Drive screws into the pre-drilled holes.
    • Use a wet scrubbing sponge to clean up the lines.
    • You may choose nails but screws are always preferable to nails when fastening deck boards.
Esther Guo
crwdns2935283:009/20/20crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
York University, Team S1-G101, Woodhouse Fall 2020 crwdns2935289:0York University, Team S1-G101, Woodhouse Fall 2020crwdne2935289:0
YORK-WOODHOUSE-F20S1G101
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 791
