A sofa storage compartment is opened and closed often so it’s no surprise that the hinges become loose over time. Most of the time it starts with a loose screw, frequent re-tightening of the screws will cause the screw hole to tear open and the screws no longer fit tightly, resulting in loose hinges.
With loose hinges the compartment cover does not close the way it should. This is very easy to fix. The trick is to fill the worn-out screw holes with something that is wood and small enough to fill the hole, like matches sticks. Wood glue is also an important element, as it helps to seal the sticks inside the hole.
This guide will instruct users how to fill the worn-out screw hole and replace the hinges.
Partially remove the inside fabric to access screw holes.
Apply glue to the match stick and insert it into the screw holes.
Break off the end of the match sticks and use a hammer to secure it in the holes
Use the staple gun to staple the inside fabric. Allow the glued match sticks to dry for approximately 5 minutes before doing the next step.
Use a Phillips screwdriver to attach each hinge to the cover of the storage compartment with two ¾-inch Flat-Head Wood screws #9.
Use a Phillips screwdriver to attach each hinge to the base of the storage compartment with four ¾-inch Flat-Head Wood screws #9.
Here is the Storage Compartment all back together and good as new!
After following this fast fix guide, the hinges should be tightly secured and storage compartment is fixed.
