Using this guide you can fix this toy in 15-20 minutes without having to buy a new one. There are several tools you will need to fix this Little Tikes Bubble Mower. You will need a Philips screw driver size PH1, and a soldering tool. (If you don't know how to solder, look at iFixit's How to Solder and Desolder connections.)
Start with a flat, open space to work.
Remove the Bubble Sprocket from the motor.
Unscrew these four 1.2mm screws holding the plate on.
Connect the red wire to the top right pin.
Solder the Red wire to the metal pin.
Connect the yellow wire to the bottom right pin.
Solder the yellow wire to the bottom right pin.
Put four 1.2 mm screws for the plate back into place.
Put three 1.2mm screws for the motor back into place.
Insert the Bubble sprocket onto the motor.
