A damaged dresser base can be dangerous in a household. This repair guide takes users through the steps of how to repair the bottom of a dresser.
Remove all drawers from the dresser.
Turn the dresser upside so that the bottom is facing up.
Using a pair of pliers, remove the existing staples from the bottom of the dresser.
Remove the piece of hardboard and realign it so that it is in the position you desire.
Use the staple gun to staple the hardboard back to the frame of the dresser.
Using the tape measure, measure the distance between the two sides of the dresser frame and then cut a beam of wood to fit these specifications.
Using the drill, screw the beam of wood into place.
To reassemble your dresser, follow these instructions in reverse order.
Hmm not sure how do refix the dressers
