How to Repair a Waterlogged Skateboard
  1. How to Repair a Waterlogged Skateboard, How to Repair a Waterlogged Skateboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Waterlogged Skateboard, How to Repair a Waterlogged Skateboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the skateboard upside down so the wheels are facing upwards.
    • Use the skate tool to remove the screws that secure the trucks to the board.
    • Two small screws on both ends of the board
    • One big screw on both ends of the board
    • Some boards don't have the same design for screws, however the process is the same and this should help you figure out how to remove it for your own board as well.
  2. How to Repair a Waterlogged Skateboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Waterlogged Skateboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Dry the board with a towel.
    • Put the hair dryer on heat mode and move the hot air over the grip tape until the adhesive softens.
    • Ensure that majority of the water is dried up.
  3. How to Repair a Waterlogged Skateboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Waterlogged Skateboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use one hand to hold the board down and peel the grip tape off with your other hand.
  4. How to Repair a Waterlogged Skateboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a dry paper towel or cloth to gently pat the exposed board and remove any remaining moisture.
    • Ensure that you flip the board every couple of hours and pat it down with the paper towel/dry towel until it is fully dry.
  5. How to Repair a Waterlogged Skateboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Waterlogged Skateboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Ensure the board is fully dried before proceeding with this step.
    • Use 150-grit sandpaper to remove any uneven rough spots.
    • Use the 220-grit sandpaper to lightly sand the surface until it feels even and smooth to the touch.
  6. How to Repair a Waterlogged Skateboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a dry towel to wipe off any leftover debris or dust remaining on the board.
    • Clean the board with rubbing alcohol and allow the board to dry.
  7. How to Repair a Waterlogged Skateboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Waterlogged Skateboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Waterlogged Skateboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ensure that the board is fully dry before applying the new tape, or else the tape will not stick properly.
    • Line up the new grip tape and start applying it to the board.
    • Use one hand to lead the tape, and the other to press down while you move forward.
    • Carefully and evenly place new grip tape on skateboard and use your skate tool to trace the shape of the board.
    • Press down on the tape one last to ensure that it sticks properly.
  8. How to Repair a Waterlogged Skateboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassemble the board, then leave it to air dry completely so the adhesive has time to set.
    • It typically takes 24–48 hours for the adhesive to fully cure. Make sure it’s secure before resuming normal use.
Kunga
crwdns2935283:001/31/25crwdne2935283:0
187 crwdns2915208:0crwdne2915208:0
York University, Team 3-1, Woodhouse Winter 2025 crwdns2935289:0York University, Team 3-1, Woodhouse Winter 2025crwdne2935289:0
YORK-WOODHOUSE-W25S3G1
crwdns2942667:0crwdne2942667:0 151
