How to Repair a Stuck or Broken Chainsaw Rope
  1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the chainsaw casing or handle.
    • This step will vary depending on what kind of chainsaw you are using. Some might only require you to remove the handle, while others have a casing you must remove instead.
  2. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw on top of the housing.
  3. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the housing unit.
  4. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rope from the chainsaw using a pair of pliers.
  5. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make your adjustments to fix any problems with the rope.
    • The adjustments needed to be made will vary depending on your specific problem with the rope.
  6. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stick the rope back through the insertion hole.
  7. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Stick the housing back onto the casing.
    • Do not screw the housing on yet.
  8. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the housing unit until the tension is maxed out.
    • Caution: Once the tension is maxed out, you must hold the housing unit firmly or else it will slide out and possibly hit you or someone nearby.
  9. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Stick the rope through the groove into the housing.
  10. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-tie the rope into a knot.
  11. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly rewind the housing unit until the rope is back into its original position.
  12. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-screw any screws used to take off the housing.
    • This step will vary. Not all chainsaws will have extra screws on their housing unit.
  13. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the casing or handle back onto the chainsaw.
    • Similarly to Step 1, this will vary depending on the type of chainsaw you are using.
  14. How to Repair a Stuck or Broken Chainsaw Rope: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull on the rope to make sure the chainsaw works.
Matthew Whetzel
crwdns2935283:002/22/21crwdne2935283:0
265 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G7, Raign Spring 2021 crwdns2935289:0University of North Texas, Team S1-G7, Raign Spring 2021crwdne2935289:0
UNT-RAIGN-S21S1G7
crwdns2942667:0crwdne2942667:0 795
