How to Repair a Stuck Trailer Jack
  1. How to Repair a Stuck Trailer Jack, How to Repair a Stuck Trailer Jack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the trailer jack from trailer.
    • Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
    • Slide the jack off the trailer to remove.
    • Be sure to safely support the trailer before removing (With a vehicle or jack stands).
  2. How to Repair a Stuck Trailer Jack: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nut and bolt that secures the handle to the jack.
    • Use two half-inch box end wrenches to remove the half-inch bolt and nut.
    • Slide the handle upward after removing the nut and bolt to remove the handle.
    • Set the handle aside.
    • Screw the jack to the most extended spot the jack will go.
  3. How to Repair a Stuck Trailer Jack: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the spacer or washer upward.
    • Set the washer aside.
  4. How to Repair a Stuck Trailer Jack: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the jack upside down and use a hammer to gently slide the upper assembly off the lower assembly.
    • Set the upper assembly aside.
  5. How to Repair a Stuck Trailer Jack: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin to remove the rust and corrosion using a die-grinder and steel wire wheel.
  6. How to Repair a Stuck Trailer Jack: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply grease or anti-seize lubricant to the screw assembly.
    • Screw the screw assembly to full extension and shortest extension to ensure lubricant reaches every section of the screw assembly.
  7. How to Repair a Stuck Trailer Jack: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove rust and corrosion from the upper and lower assemblies of the jack using a die-grinder and sanding pad.
  8. How to Repair a Stuck Trailer Jack: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Paint the upper and lower assemblies for prevention of future rust and corrosion.
  9. How to Repair a Stuck Trailer Jack: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • During re-assembly, align the notch on the upper assembly to the grove on the lower assembly.
  10. How to Repair a Stuck Trailer Jack: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hammer to force the upper assembly over the lower assembly.
    • Be sure to align the grove and notch of the assemblies.
  11. How to Repair a Stuck Trailer Jack: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the washer and the jack handle over the stud of the jack.
    • Insert the bolt through the handle and the hole located on the stud.
  12. How to Repair a Stuck Trailer Jack: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the jack to the trailer and test for correct operation.
Cody Gearin
crwdns2935283:003/25/20crwdne2935283:0
336 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S5-G10, Willis Spring 2020 crwdns2935289:0University of Memphis, Team S5-G10, Willis Spring 2020crwdne2935289:0
UM-WILLIS-S20S5G10
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
Loren Turner - crwdns2934203:0crwdne2934203:0
What if the trailer jack is frozen in the position. And the gears on top are well greased?
Wesley Ramsey - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 219
crwdns2942667:0crwdne2942667:0 22,971
