This fix will restore your fan's original power and quiet operation. This fix does not require new parts, but does require a #1 Phillips head screwdriver, an 8mm wrench or socket, and a medium or low viscosity lubricant.
Loosen the 4 phillips screws around the rim and remove the front of the cage
Remove the fan blade by loosening the screw on the shaft while pulling up.
Remove the wiring cover located above the fan motor.
Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
Remove the final 2 screws holding the mounting plate to the cage.
Carefully pass the motor through the opening at the back of the cage.
Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
The 8 mm nut is on very tight. I used an 8 mm socket (1/4” drive).
Clean and lubricate the magnet shaft and mounting brackets
To reassemble your device, follow these steps in reverse order.
crwdns2935229:05crwdne2935229:0
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Mine did the same
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
