How to Repair a Loose Embroidery Stitch
  1. How to Repair a Loose Embroidery Stitch, How to Repair a Loose Embroidery Stitch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gather all the necessary materials for your fix following these guidelines:
    • Pick the proper embroidery needle size. Lightweight fabrics can use a smaller needle, while heavyweight fabrics will need a larger needle.
    • Ensure that you pick a color of embroidery floss that matches the color of the thread you are trying to fix.
    • If using a lightweight fabric (e.g. cotton), use an embroidery hoop to stabilize the fabric.
  2. How to Repair a Loose Embroidery Stitch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Loose Embroidery Stitch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Loose Embroidery Stitch: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Embroidery floss consists of six different strands.
    • Separate the strands and decide how many you will need to thread.
    • Pull the strand(s) through the eye of the needle and ensure that the needle is in the center of the strand(s).
    • You should have double the amount of floss once threaded than when separated.
  3. How to Repair a Loose Embroidery Stitch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Loose Embroidery Stitch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Loose Embroidery Stitch: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To tie the floss, wrap the end around your pointer finger three times.
    • Slip the wrapped strands off your finger, and then pull the needle through the center.
    • Pinch your fingers where the longest part of the strand meets the wrapped portion and pull towards the end of the thread.
    • This should form a messy knot.
  4. How to Repair a Loose Embroidery Stitch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Loose Embroidery Stitch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the needle and thread through the fabric as close to the loose thread as possible.
    • Push the needle and thread down through the other end of the loose thread.
    • Repeat these steps 3 to 4 times going over the thread until it becomes flush with the rest of the embroidery pattern.
    • Be aware of where your hands are located while using the needle.
  5. How to Repair a Loose Embroidery Stitch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To tie the anchor knot, push the needle and thread through an existing stitch or fabric hidden under the pattern. This should form a loop when you pull the needle.
    • Place your needle through that loop and pull to create an anchor knot.
    • Repeat this step 1-2 times to strengthen the knot.
  6. How to Repair a Loose Embroidery Stitch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the knot is finished, the thread should be completely flush with the rest of the embroidery pattern.
  7. How to Repair a Loose Embroidery Stitch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To strengthen the embroidery you may use either fabric glue or a steamer. If you are using a lightweight fabric, make sure you use an embroidery hoop.
    • To use fabric glue, apply 1-2 drops everywhere that there is embroidery on the back of the fabric. Allow this to dry for at least 5 minutes.
    • If using a steamer, follow the instructions to turn it on for your particular model. Run the steamer over the back of the fabric two times. This will make the stitches taut.
    • Test the steamer first on the fabric in a hidden area before steaming to avoid staining or burning your work.
Samantha Cook
crwdns2935283:009/27/23crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
University of Arizona, Team 6-2, Cools Stephens Fall 2023 crwdns2935289:0University of Arizona, Team 6-2, Cools Stephens Fall 2023crwdne2935289:0
ARIZONA-COOLS STEPHENS-F23S6G2
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 750
