In this guide I will show you how to sew a ripped pair of yoga pants at the crotch. You don't need to know how to sew, but a basic understanding of sewing is helpful. The thread in this guide is a different color the yoga pants to provide contrast in the pictures. However, you should use a similar color thread to your pants, so the thread doesn't stick out.
Take the pants and put them inside out.
Take the sewing pins (if the hole is big) and pin closed along the seam.
Take the thread (make sure it is the preferred color that matches the pants) and thread it through the needle.
Make sure to leave a large tail at least 20 inches.
Tie the two ends together into a small knot.
Insert the needle into the fabric from one side until you can see the needle on the other side.
Pull all the way through.
Take the needle and put it back through the fabric a short distance from where it came out originally.
Continue steps 7 and 8 until you have reached the other end of the hole.
Once you have finished sewing the hole, take the thread and tie a small knot at the base of the thread.
Cut thread and reverse the pants to check the seam.
If seam is completely closed, then you have done it!
If not, then repeat steps 7-11 until hole is completely closed.
If seam is completely closed, then you have done it! If not, then repeat steps 7-11 until hole is completely closed.
